H3 Radiator
BradinNC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BradinNC Quote  Post ReplyReply Direct Link To This Post Topic: H3 Radiator
    Posted: 10 Apr 2011 at 10:29am
I'm looking for a used radiator for my H3. Will a D14 or D15 radiator fit it?
It has the 149 engine.
Thanks,
Brad
Kipn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kipn Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2011 at 10:07am
Sorry, but I don't know. Haven't had to replace mine. the engines are the same. The hoods, one is shorter probabaly due to the heavier radiator shroud on the H3. Take some measurements and compare.
1961 H3
Post Options Post Options   Thanks (0) Thanks(0)   Quote BradinNC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2011 at 12:32pm
I figured I would post my results for the archives. I bought a new radiator for a D-15. The shroud was 1 1/4" to long. I used a cutoff wheel on a side grinder to trim it. The over flow tube protrudes straight out form the radiator neck on the new one instead of tilting downward . It will have to be trimed or bent down slightly to keep it from hitting the H3 heavy duty radiator cover. All the mounting brackets matched. I can post pics if needed.
Kipn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kipn Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2011 at 12:18pm
Thanks Brad. To many times problems were asked here and solved but without letting anybody know the solution. I'll keep that in mind if I ever need one, although mine is in pretty good shape.
Something tells me that the hood on a H3 is 1" or so shorter than a D15.
1961 H3
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 10:59pm
You are correct Kip
graham7226 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote graham7226 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2013 at 9:40am
I know this is an older post but if your still around I'd really appreciate some more information on how this worked out for you. I've been thinking of doing the same but from what I can tell my radiator cover is 16 1/2" wide and the D15 radiators appear to be listed at 18" wide, at least on the website I was looking at. Thanks
Allis HD3 w/ 1066
John Deere 440 ICD
Cat 955 12A Traxcavator
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2013 at 10:12am
Didn't someone recently advertise a Radiator for a D-14 with Shuttle Clutch.
Does a Shuttle Clutch have Cooling Lines to the Radiator ?
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2013 at 4:27pm
the H3 that I had, was set up with the external oil cooler mounted in front of the radiator so there is no need to worry about the oil cooler lines. The shroud is another story, like was mentioned above to long and has to be cut off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote graham7226 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2013 at 5:48pm
Thanks for the reply. This H3 also has the external oil cooler. The main thing I am worried about is the width of the radiator, as in between the two mounting rubbers on each side of the rad grill. By shroud you mean the part that extends toward the fan? Do you remember who you bought your radiator from?
Allis HD3 w/ 1066
John Deere 440 ICD
Post Options Post Options   Thanks (0) Thanks(0)   Quote graham7226 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2013 at 6:42pm
My mistake. After remeasuring the grill it is 18 1/2" wide, not 16 1/2", apparently I don't know how to use a measuring tape. So I'll be getting a new D15 radiator from superior cooling system. Will post pictures after I get it fitted.
Allis HD3 w/ 1066
John Deere 440 ICD
This page was generated in 1.797 seconds.
