1942 C oil bath / running issue
442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 442 Quote  Post ReplyReply Direct Link To This Post Topic: 1942 C oil bath / running issue
    Posted: 10 Apr 2011 at 10:25am
Hi,
   I have a problem with a 1942 AC C tractor that I recently bought .  It starts right up and runs fine with no oil in the oil bath cup, but when I add oil to the cup and start it up, it runs for a minute or so and cuts off.  I am not able to start it after that.  If I empty the cup and let the tractor sit for a couple days it starts right up.  Is it possible I have too much oil in the cup and it is being sucked into the carburetor?  I had the oil level about a 1/4" below the top of the little sediment bowl in the center of the cup.  Any ideas from anyone?
Thanks,
Richard.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 10:31am
Sounds like the steel mesh in your air cleaner is plugged up.  Some people take it apart to clean.  I threw mine in the hot tank while the engine block was getting done.  Came out sparkling clean - mine was chocked full of mud and corn tassles!
442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 442 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 10:43am
I think the air cleaner has been replaced, it looks brand new with no dirt or anything in the steel mesh.  Very strange!
NICKMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NICKMI Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 1:58pm
there should be a fill line on your cup if your below the top of the cup a quarter of an inch thats probably too much oil
442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 442 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 4:41pm
Should the oil level be above the intake tube, or should the intake be above the oil level when the cup is installed?
Thanks,
Richard.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 4:47pm
Air coming in to the cleaner has to be drawn through the oil. Oil will be sucked up and coat the wire mesh so dirt particles will stick to the oily wire. The cup should have a ring around it with the words oil level stamped somewhere on the circumference.
442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 442 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 8:35pm
Thanks, I don't see an oil level mark inside but it is an old piece.  I will check more carefully to make sure.
Richard.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 8:45pm
Look on the outside for a ring around the cup.
