d15 diesel battery box
Jerry fl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jerry fl Quote  Post ReplyReply Direct Link To This Post Topic: d15 diesel battery box
    Posted: 10 Apr 2011 at 9:11am
 who out there has a fender battery box for a d15 diesel that i can give photos of or if some one has on for sale that would be nice as so thanks Jerry
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 10:48am
 will check inventory in morn. 1-800-254-3116
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jerry fl Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 4:33pm
thanks norm
EdIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EdIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2011 at 3:00am
I need one of those battery boxes also.  Can I get pictures and dimensions or an original?
Thanks     Ed
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2011 at 6:24am
Here is a copy of my previous post-
The Auxiliary Battery Box (D15 II Diesel ) I have mounted next to the right fender, measures 6W x15L x9H, mounts via two "L" brackets to the top two axle bolts, is not centered over the axle, and through the fender mounting bracket. It appears that it can also be used on other "D" series diesel's because of all the other square/rectangular holes on the fender side.  I have pictures somewhere, but could get some next time I go to the farm.
This is pic of when it appeared at the farm a decade ago.
Edited by JoeO(CMO) - 11 Apr 2011 at 6:37am
FredW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FredW Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2011 at 10:53am
I suppose if you want it original you would put one on, but mine works fine with a good battery under the hood. Fred
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jerry fl Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2011 at 4:20pm
I need it to be original .
Post Options Post Options   Thanks (0) Thanks(0)   Quote FredW Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2011 at 4:38pm
In that case I will check the old box and maybe I can add some info, Fred
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jerry fl Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2011 at 4:46pm
thanks fred any help you can give would be great
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2011 at 8:59pm
Our D15 only has one battery under the hood.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
