WD oil filter
KC/WD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KC/WD Quote  Post ReplyReply Direct Link To This Post Topic: WD oil filter
    Posted: 10 Apr 2011 at 8:36am
I need a oil filter for my '49 WD, does O'Reiley have a compatible filter and if so anybody got a part number?
Thanks for any input!
KC
I've got anal glaucoma, I just can't see my butt going to work today!
Chad(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 8:40am
I use Baldwin T-300M filters. They should be able to cross that number.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KC/WD Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 8:57am
Baldwin filter huh Chad, I'll check that out, thanks.
KC
dannyraddatz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dannyraddatz Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 9:41am
I show a NAPA 7011 used on that year tractor. That can be crossed to a WIX number also.
Danny Raddatz
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 10:17am
If you have a Agco dealer close by (LOL) I would get it there. I bought several last month and they were about $9.00 each. Could have gotten them cheaper somewhere else but these filters said Allis Chalmers on them and looked really cool to me.
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 10:19am
fram 159
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 10:47am
Wasn't Steve at B & B selling filters also at a good price ?
Faith isn't a jump in the dark. It is a walk in the light. Faith is not guessing; it is knowing something.
"Challenges are what make life interesting; overcoming them is what makes life meaningful."
Post Options Post Options   Thanks (0) Thanks(0)   Quote KC/WD Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 10:47am
Thank You Gentlemen, I knew you'd come through in a clutch!
KC
hotrodpierre View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hotrodpierre Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 10:50am
Carquest #84011. Correct me if i am wrong, but didn't they have some issues with the fram 159? Something about the media used on the inside that reduced oil pressure?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 12:19pm
believe it was the NAPA filter that had the problem as media and tube in filter did not create back pressure.
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 12:23pm
O'rielly's will have Wix. You need part#57011 and it is the right one for your tractor.JP
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 12:38pm
It was NAPA that had the bad filters, they have gone back to the old stile filters now.
Here's the dope on then. Thanks to Jim at OK Tractor.
Don
Edited by Don(MO) - 10 Apr 2011 at 12:45pm
48AC/WD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 48AC/WD Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 1:37pm
Mine is a Baldwin T300-M , its a great filter, google it in the shopping feature of google, they are about $14 each.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 1:43pm
 The Fram C159 was the only filter that didn't have issues. The others, even the ones AGCO sold were re-engineered to save money and caused more than a few engine failures.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 7:57pm
If the filter has a pleated paper element it will kill the engine by preventing proper oil pressure. Only the filters made of waste material in a bag have the proper flow restriction to hold up oil pressure.
Gerald J.
Cal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cal Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 8:47pm
The AGCO part # is 70240912, that is the same as the AC #  from the past. Cal in Ct.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2011 at 6:19am
Absolutely right Coke. We always have our filter program going. Still the same price after 6 years for the Orange family here. C159 Fram's $7. bucks each. Four or more $6. bucks each. Have about 58 in stock at present. We always bring 8-10 cases to the Tractor shows with us if ya wanna' save on the shipping...
Post Options Post Options   Thanks (0) Thanks(0)   Quote KC/WD Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2011 at 9:11am
The Wix 57011 works like a charm. Great operating oil pressure, my girl's got fresh oil and filter, plugs pulled cleaned gapped (plugs were kinda carbed up), every grease port hit w/fresh grease, mower deck blades sharpened, ALL systems GO ( I shulda gave her a bath)!
Bring on the mowing season!!!!
Thanks Again AC family!!!
KC
