DIY repairs
Steve allis dozer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve allis dozer Quote  Post ReplyReply Direct Link To This Post Topic: DIY repairs
    Posted: 10 Apr 2011 at 5:49am
Running older machines  Sometime  you have to make your own parts
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 6:39am
Man that sure is pretty ! Too bad it'll get dirty soon !!!
You'll have to take one of the belts off thouh and move it a 'tad' to line up with the other one, lol !
Tad Wicks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tad Wicks Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 8:57am
Well done, , it turned out beautiful,you have a bit of time in that project. Nice clean shop, nice tooling, Great Job.   Tad
JPG AUSTRALIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2011 at 6:46am
great job steve,I'm impressed, keep them going.
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2011 at 6:53am
WOW!  That there is PURDY!
Greg Kroeker
Kipn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kipn Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2011 at 10:01am
Nice job. Just curious on what your yellow paint code that you used was?
1961 H3
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve allis dozer Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 3:06am
 Hi all, thanks for the replies , Paint colour is old cat yellow.  steve
rayfromTX View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rayfromTX Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 7:17am
Man that is awesome. Congratulations on a fine job.
Rawleigh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 3:24pm
What lathe tool did you use for turning the  v belt groove?  I had to be pretty small to get all the way to the bottom.  BTW, beautiful work!!
Edited by Rawleigh - 12 Apr 2011 at 3:25pm
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve allis dozer Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 7:16pm
 I machined the front side recess then turned it around held it there with  the inside jaws got it running true with a dial indicator ,  machined the whole lot including the bore and keyway without taking it out so it all ran true,( the original pully was balanced but i figure this was because it was cast and some surfaces were not machined) for the grooves  I used a 3mm wide parting tool down to the right  depth, then a home made tool which i had to hold at the back of the toolpost as the pulley was to big for my lathe , for the surface the seal runs on i fitted a stainless speedy sleeve and polished with emery cloth.
The keyway was done using a home made tool held in the toolpost then winding the saddle back and forth with the lathe switched off and in low gear as not to move .  steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2011 at 11:04am
Nice tool setup to machine the grooves!  Necessity is the mother of invention, isn't it!  Do you have a picture of the tool you used to make the keyway?  Thanks and nice work.
