brakes
abbaschild95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote abbaschild95 Quote  Post ReplyReply Direct Link To This Post Topic: brakes
    Posted: 09 Apr 2011 at 9:26pm
ok so in theory should i be able to pull the whole hand brake out of my WC if i get the cotter pin on the outside out then tap it with a hammer? i really need to get it done.... just curious. any experience taking it apart?
Great-granfather's WC---- hopefully many more to come!
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2011 at 10:01pm
The shaft that the cotter pin is in needs to come all the way out of the housing so the band can come out. Of course you first have to remove the spring and adjusting nut and push the bolt out of the toggle.
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2011 at 10:17pm
Did both sides last year, and by tap, yes, SEVERAL, WITH A THREE POUND HAMMER!  That removes the handle, as for the rest of it, The I & T manual explains it pretty well, just be sure to mark the plate and housing with a chisel, it will save  you lots of frustration later.  Also, do one side at a time.
