One-sixty Starting Issue #2
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Topic: One-sixty Starting Issue #2
    Posted: 09 Apr 2011 at 8:26pm
Well, still messing with the one-sixty starting issue I posted a week or so ago.  As I previously mentioned, I can get juice to the started to turn it over and start when I have the battery charger on.  It doesn't turn the starter at all without the charger connected.  The light on the insturment panel along with the headlights work.  It is a new fully charged battery (I even tried a different new battery).  I have cleaned all of the connections and today put new battery cables on.  I am really stumped on this one, because it starts right up with the charger hooked up, but doesn't turn anything over without it.  Is there some other place where a ground connection could be causing a problem and with the charger I am providing the ground to start it?  Any help or suggestions are appreciated.  Thanks, Dave
bobkyllo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 6:40am
have you tried to clean where the starter mounts to the block? how about taking a ground cable and mount one end to the starter and bolt the other end some place else that would make a good ground. have you tried to check the key switch to be sure its not that?
