Decal removal
rrhead(SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrhead(SD) Quote  Post ReplyReply Direct Link To This Post Topic: Decal removal
    Posted: 08 Apr 2011 at 9:07pm
My 6080 had some of the Deutz-Allis decals left on it. I got them off with no problem. The only problem is someone else had tried to take them off and left a film of sticky residue on the Allis decals. When I tried to use the heat gun to take it off it gets the Allis decal too hot. How can I get this residue off? Any help would be appreciated. rrhead(SD)
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2011 at 9:31pm
Scrub it with gas or paint thinner. You will have to do it several times because the gooey stuff will build up on your rag. I would try not to get it on the edges of the AC decal.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2011 at 9:33pm
Mine was peeled off long ago but still has residue.  Have you tried some paint thinner?  It might work if the residue is still sticky.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2011 at 2:44am
3-M makes a spray that will remove the decals and the glue, just spray on, let sit till it bubbles, and wipe off, careful, as it don't take long, and if left on, it'll take the paint too! used it on police cars, works really good!
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2011 at 6:39am
I just got done removeing the decals and grafics from a used truck that i bought.
The 3M remover works great but takes time and lot of rubbing.
The universal answer to all questions is yes, how much do you want to spend?
Brad(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2011 at 7:16am
I used Goof Off on my decals.  peeled decals off and used it. took sticky off and didnt hurt paint.  sold in alot of stores-Home Depot, Wal-mart, etc.
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2011 at 7:32am
If the residue is still sticky, WD40 will remove it, where paint thinner will just gum it up. That is how we removed the muffler sticker on Skip Welte's C project at the Gathering last year.  Dave.
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2011 at 2:29pm
We use Goo-Gone on them. Most stores have it.
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2011 at 10:50pm
If it's still sticky; peanut butter works pretty good & will not hurt the other decal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrhead(SD) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 6:39am
Thanks for all the replies. I will give the ones I have a try first. If I need too I will look for the 3m and goo gone. I'll save the peanut butter for last. I kind of like eating that the best! rrhead(SD)
Edited by rrhead(SD) - 10 Apr 2011 at 6:40am
