D19 Narrow front conversion
allisnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisnut Quote  Post ReplyReply Direct Link To This Post Topic: D19 Narrow front conversion
    Posted: 08 Apr 2011 at 11:02am
I was thinking about if I could Put a narrow front off a d17 series one on a d19 gas.
Are the narrow pedstals the same on the d19 and d17
thank you
Phil
Bob(FL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob(FL) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2011 at 11:07am
I think one is shorter than the other, may be wrong.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2011 at 11:08am
D19 pedistal is a couple of inchs longer. Bolt pattern is the same. HTH
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2011 at 12:07pm
When converting you also need a casting that fills the space between the grill and steering gear housing otherwise the grill shell will be just kind of hanging out there by it's lonesome. They are a bit hard to find but not impossible.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisnut Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2011 at 2:45pm
HI guys thanks for all the info
this was just an idea i was kicking around
This page was generated in 0.095 seconds.
