my wd's
firstac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firstac Quote  Post ReplyReply Direct Link To This Post Topic: my wd's
    Posted: 06 Apr 2011 at 6:59pm
I have just inherited 2 wd's one of them is a 1951 on the other tractor I can't make out any of the serial # my question is? Is there any other way to date this tractor?
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2011 at 7:13pm
Sometimes you can find a casting # on the rearend that would be a close date or you can go off the engine serial#.
Post Options Post Options   Thanks (0) Thanks(0)   Quote firstac Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2011 at 7:38pm
thank you for the info where would I find the engine serial # and then where do I locate info on engine #"s or casting #"S
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2011 at 7:42pm
The engine serial number should be sort of behind the carburetor. Welcome to a great forum!
David Gibson (OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Gibson (OH) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2011 at 8:00pm
Welcome to the forum!
David Gibson
http://www.darkecountysteam.com
1956 WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2011 at 8:04pm
The engine # will be hand stamped and start with WD##### unless it's a newer WD45 engine, then it will start with 45-#####. Here is a site that has the info.
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2011 at 8:05pm
the serial no on the hydraulic pump should match the tractor serial no.....if the pump is original. but, I suspect that if you spend a little time scraping paint you will be able to read the serial no on the tractor differential. Nothing but the differential no will be for sure, because during it's life motors, pumps, etc could of been changed
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2011 at 8:07pm
Go here and look at the correlation between the year and engine serial #s:
http://people.clemson.edu/~wsmth/SNFind/esn_tsn5.htm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2011 at 8:08pm
Some of the early WD's were stamped to the right side of the left brake cover also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote firstac Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2011 at 8:13pm
would that be on top of the brake housing or on the back because I have removed the paint under the hole where I found the serial # on my 1951 and the casting is a little pitted but I dont see any numbers there. I tought I should be able to make out something but I see nothing
1951 WD, 1948 WD, 1937 unstyled WC (NW Ohio)
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2011 at 8:27pm
On top, to the right of the cover.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2011 at 8:34pm
I found the serial # right of the left break cover # 3348.
So you have a fairly early WD from 1948.
Post Options Post Options   Thanks (0) Thanks(0)   Quote firstac Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2011 at 8:35pm
Thanks everyone for your help I have located the Serial # on top of the break housing and it is a 1948. Thanks
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2011 at 8:51pm
Welcome aboard! Great bunch here. Answers for any questions you may have.
I didn't do it! It was a short, fat, tall, skinny guy that looked like me!
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2011 at 9:05pm
You try flowers and a serenade? LOL
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote firstac Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2011 at 9:09pm
I hope to start restoring both of my wd's sometime in the near future so I may be posting my questions. I haven't pick up my '37 WC yet but I should have it in a few months. I also have aquired (3) lil genius two bottom plows which should be a lot of fun when I get them functional.
Post Options Post Options   Thanks (0) Thanks(0)   Quote firstac Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2011 at 9:12pm
lonn love the humor
