best wax/substance to bring out color
Matt (NEIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (NEIA) Quote  Post ReplyReply Direct Link To This Post Topic: best wax/substance to bring out color
    Posted: 05 Apr 2011 at 5:51pm
What is the best solution/product to use on old tractors to bring out the paint and give them a good shine?  Before i repaint my tractor i'd like to see first how good i can make it look using something on the origional paint to brighten it up so to speak.
1955 WD-45 with factory PS
Chris(WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris(WA) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2011 at 5:55pm
Cheap and easy is to spray it with WD-40 then wipe. Works better than I thought it would.
Washingtonian by choice, Wisconsin Farmboy by the grace of God!
JPG AUSTRALIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2011 at 6:43pm
give it a coat of penatrol,best thing Ivé found after trying dozens of other tricks over the years.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2011 at 6:47pm
 Don't wax , if there is even a chance you will refinish. The local Kubota/ Agco dealer told me once upon a time they polish used tractors with orange hand cleaner with the grit [ pumice] in it. Try it on a small spot.
jjwo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jjwo Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2011 at 6:51pm
Believe it or not, we have used it on campers for years, aerosol bathroom cleaner.
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2011 at 6:54pm
Wizards Finish Cut. Hands down the best thing Ive used. It was recomended by a buddy of mine whos a body man. I was gona repaint but, it did such a good job of taking the oxidation and bringing back a shine Im gona wait a lil bit on the paint.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2011 at 7:08pm
I tried that on our farmall smta on a spot around the muffler and it turned a very preaty red and not the ulgy faded color. I was just trying to clean off some carbon on the hood and it worked great for bring back the orgional color!
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2011 at 8:38pm
There is an excellent gritty type of rubbing compound from Napa that I use on many faded tractors and it works excellent.  You can add water to it if you don't want it as gritty, just don't use it on anything with a clear coat. LOL
