Reinstalling D15 II head
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Topic: Reinstalling D15 II head
    Posted: 05 Apr 2011 at 11:21am
gasket question. Do I use sealer above and/or below head gasket when I put the engine back together or just use head gasket? Thanks, Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2011 at 11:25am
Dana, Head gasket only. Make sure it has the fire rings, or don't use it. Torque per specs, set valve lash and install valve cover.( Make sure rocker arm shaft has plugs in ends and is oiling properly.)Dana, Make sre gasket is oriented correctly, to reduce water flow properly. HTH Tracy Martin
Edited by Tracy Martin TN - 05 Apr 2011 at 11:27am
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2011 at 3:59pm
I spray that gasket with silver paint, both sides.
"Burgie"
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2011 at 5:11pm
Thanks! Off Topic...Here's a shot of the Ches Bay Bridge and Tunnel I took yesterday from FL390. I saw this twice yesterday morning going to and returning from Boca Raton from the Upstate NY!
This page was generated in 0.048 seconds.
