Gleaner K corn head
mjhettler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mjhettler Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner K corn head
    Posted: 04 Apr 2011 at 8:11pm
Does anyone know if they made a 4 row narrow corn head for a Gleaner K? I've seen 3 RN but not 4 RN. If they did not are there any that can be adapted?
Dean/MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean/MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2011 at 9:17pm
Not sure if a head from a F will fit an K or not.
Not mine, on local CL
Gleaner F combine - $1400 (Waseca) Date: 2011-03-28, 5:21PM CDT
Reply to: sale-haccv-2292110989@craigslist.org
Gleaner F combine, gas, with following heads: 4 row narrow corn head, 3 row narrow corn head, 4 row wide corn head, 15 foot bean head. Has been sitting in shed and not ran for several years. $1400 all to go .
Location: Waseca it's NOT ok to contact this poster with services or other commercial interests
HD16,917H,185,7050,8030FWA,8050FWA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2011 at 10:31pm
Believe you could run a black a430 head on a K2 as it had a little extra separator area capacity vs a straight K.  I think header helper springs, heavier lift cylinders & rear weights were needed?  There might also have been a clean grain elevator speed up kit.  Probably have a hard time keeping up even in first gear.  I would not not recommended trying it on a straight K unless you are running about 100 bu corn or less.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2011 at 4:48am
yeah...120 bu corn with a 3 row is all it wants to handle in the clean corn elevator in 1st gear! the combine will handle the harvest and cleaning part but can't get it to the bin fast nuff! maybe if you put a larger elevator on it from another combine, then the 4 row would work fine!
Post Options Post Options   Thanks (0) Thanks(0)   Quote mjhettler Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2011 at 11:55am
Thanks all for the feedback... Sounds like I need to upgrade to a bigger machine for 4RN
