Modifying an All Crop for dehulling??
KevinON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Topic: Modifying an All Crop for dehulling??
    Posted: 03 Apr 2011 at 10:04am
As usual, I have a crazy idea.  I am looking to dehull spelt.  There are very expensive machines on the the market to do this job, but I am wondering if you were to feed the spelt into the feederhouse of an All Crop, could you not do the same thing as an expensive impact huller??  You can knock the seed out of the hull if the combine is set too tight, so I am thinking it could be done with the rubber concave of the All Crop.  Those that don't get dehulled, would come back through the return.  Any thoughts??
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 3:17pm
 I have a manual on all crop 60. It list 106 crops and how to set up.It is form TPL_86F IT list Spelt and set up cyl speed 1400 to 1600 ,no.con 1-2 clearence shell pt.3/8 ot5/8 concave 3/8  to5/8 sive none bu . wt. 40. Hope this helps. Question what is spelt.
Roddo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roddo Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 4:14pm
Cant beat a wiki page to learn new things...
http://en.wikipedia.org/wiki/Spelt
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 4:16pm
Thanks, wfmurray.  I am wondering if this setting for the AllCrop takes it out of the hull, or leaves it in the hull?
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 6:41pm
Based on the spelt harvest from an all-crop I saw years ago, the hull remains.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 7:26pm
Don,t know  about hull on spell but i have seen it take the husk of oates.
