CA Hydraulic Pump
Jim-Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim-Ohio Quote  Post ReplyReply Direct Link To This Post Topic: CA Hydraulic Pump
    Posted: 02 Apr 2011 at 2:12pm
Does anyone have pictures they could post of disassembling and rebuilding a CA hydraulic pump? The exploded drawings in the service manual don't show a whole lot.
Thanks
'61D17, '51WD, '51CA, '41C, '49C, Woods 5'&6'Mower, 6'Blade, CA-Plow, CA-Cultivator, 3-Btm snap-coupler plow, 4-row planter, WD 4-row cultivator, 80R mower,#7 mower,B/C mower
Tedin NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tedin NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2011 at 4:56pm
Sandy Lake Implement will rebuild your pump if you want . They also stock parts.            1-888-252-0656
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2011 at 5:43pm
Glad I'm not the only one who thought the 'manual' was incomplete. I took a lot of picture before I tore mine apart,found out WHY a good clean well lit bench is necessary, especially a lip on the back. Had one of the check balls 'roll' onto the floor, 2 hours later found it...
I do remember the 'guts' of one of the pressure relief valves( up front) wasn't clean.Took me 3 tries to do it right,but once everything was clean the pump and valves performed great.
I'll look for the pictures and any papers I have, PM me to remind me in a day or so.
Jay
kmckemy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kmckemy Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2011 at 12:16pm
Hello, I am rebuilding a pump now, do you still have the pictures?
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2011 at 9:12pm
Here ya go!
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2011 at 7:31am
Very nice Bill!
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2011 at 8:07am
Excellent Pictures.  Again on my computer.
Remember, the CA and the WD-WD45 pump are the same.  Just in different locations.  Also, remember that the CA pump can be idle if the PTO is not engaged.  We found stuck pistons because of it.  May be wise to run it from time to time.
As said above be very careful.  Use a clean bench with edges on it.
Remember, If I can do it I know you can.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote kmckemy Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2011 at 8:11pm
Thanks for the pictures, it is back up and running now.
steve View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2011 at 9:46am
One word of caution, be certian that if a shop rebuilds it, that they pressure test it before it is returned. Had a reputable shop "rebuild" a CA pump which never worked when I got it back. They replaced all seasl, which were excellent to begin with. $375 of wasted money. I won't ever buy from them again. It was my second, very expensive problem with the business. I just expected to get what I paid for. stupid me.
51 CA, 57 CA, 53 CA(in progress)
bjacobs113 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bjacobs113 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2021 at 9:20pm
Can anyone tell me if the Plungers that go under the 4 rollers get o rings in the 2 grooves they each have?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2021 at 8:28am
No o-rings, as far as I can remember.....
if 'similar' to D14, for sure NO orings.....
Skies 1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skies 1 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2024 at 8:40am
Just a question is the wd 45 pump similar
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skies 1 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2024 at 8:42am
Oh I see the post above I didn't. See before they are the same
This page was generated in 0.101 seconds.
