allis chalmers 310
Mowermark View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mowermark Quote  Post ReplyReply Direct Link To This Post Topic: allis chalmers 310
    Posted: 02 Apr 2011 at 8:03am
Need parts for a 1970 310 garden tracktor trying to restore it in very good shape need parts for varie sppeed controle any help or ideas of where i can get parts  .
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2011 at 9:21am
I parted a 314D w/ variable drive Rear in it. I'm not sure what I kept for control parts off it. Do you have a list of part[s], numbers, anything you can send me??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mowermark Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2011 at 9:48am
What i need is the bilevel gear box shaft is wore going out the right side of the tracktor(standing behind the tracktor) everything after that i will get my prints out and get you the#s pully sleve ect if you can help me would apprecated ,i did not  get the gear bx out yet i will have to take it apart and maybe make one ,but not sure how the gears are hope good ,hope you can help me out? thanks Mark ps i will get back to you later with the part # give me a little time. do you think you can help?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mowermark Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 6:54am
what i need is the pully assembly #s2027008&2027692 they listed as pulley assembly halfs,also need the retainer assembly with bearing this should be in the first half of the pully also #2027002 fork assembly bevel gear housing.The shaft that i need with this mess is#2027986 shaft drive (variable speed) hope someone can help me out if you cant can you put me in a direction as to where i can go if you can thanks alot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 7:06am
Will get a look at that rear assy in barn, all those parts you need are on that assy. Not sure of there condition, will have to remove and inspect parts. Have another variable from B-100/200 series which may also bolt right in, [ maybe not?]. Will get back with you, take pic's and send to you.
This page was generated in 0.359 seconds.
