185 engine clutch
ssoper4014 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssoper4014 Quote  Post ReplyReply Direct Link To This Post Topic: 185 engine clutch
    Posted: 01 Apr 2011 at 9:52pm
when i push the clutch pedal in and try to sheft the gears grind is there a clutch brake adjustment on it or is the clutch bad.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2011 at 10:40pm
There is no clutch brake adjustment. Freeplay at the clutch pedal should be 4 inches or less. If it has been fine and now it isn't, I'd say you have a throwout brg failing or just simply time for a clutch. How many hrs are on it??
