model b front main.
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Topic: model b front main.
    Posted: 01 Apr 2011 at 6:00am
What are you guys using on the cork style front main on a model B to keep it from spinning in the housing. I put together a B motor and everything was good until last night the oil is RUNNING out of the front main seal. I looked in there with it running and the little cork seal is spinning with the crank
1968 D15D,1962 D19D
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2011 at 8:09pm
bump
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2011 at 9:11pm
The retaining washer was not compressing the cork gasket. You should have had two cork washer looking gaskets in the set that has the cork front seal. It takes both to have the retaining washer to compress them. At least it did on any gasket set I have bought. If they are packed in correctly they will not spin.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2011 at 7:18am
Ok, got the seal figured out, except for the crank isn't centered in the seal.....probably why the cork seal didnt hold up. How do I get this centered....i tried moving the cover with the bolts loose but it doesnt wanna move
1968 D15D,1962 D19D
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2011 at 7:59am
We have found a seal that  has a rubber lip, plus felt, kind of like a duplex. The only bad is that it fits the WC-WD, so you have to bore the front cover out to fit it. That takes care of the spiral groove on the shaft.  Dave.
