WC distributor
abbaschild95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote abbaschild95 Quote  Post ReplyReply Direct Link To This Post Topic: WC distributor
    Posted: 31 Mar 2011 at 11:22pm
ok i pulled the distributor off this evening. its pretty rusted on the outside and semi nasty on the inside. what do i need to do to clean it up all the way and getting it run like new? can i tape off the places i dont want sand and sandblast??? thanks
Great-granfather's WC---- hopefully many more to come!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2011 at 7:32am
WC's were usually Mag fired unless a change-over to a Distributor was done. If there was a change-over done, we carry rebuilt/exchange Distributors in stock if interested. Rebuilt top to bottom, ready to drop in. If its a Mag, we rebuild those also, but at the present time with my heavy work load, we don't have any Mags ready to roll on the shelf for exchange. Would havta' do your Mag......
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2011 at 8:40am
If it just needs cleaning up, I't use a wire brush.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote abbaschild95 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2011 at 12:36pm
ok yes it was converted. i should have mentioned that. i just want to know how to make it work betteer than it ever has. it still works good but i like things to be the best they can.... thanks again!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2011 at 8:15am
An electronic ignition is a great start once the nastyness is cleaned up on the inside. Make sure the main shaft bushings aren't worn to where the main shaft wobbles. If you can move the main shaft side to side, it needs to be rebuilt. If it only moves a fuzz, yer' good to go, and as I mentioned, an electronic ignition upgrade is a good move. If your WC is still 6V, you'll need the 6VPG E.I. kit. We have em' in stock if interested. HTH
Steve@B&B
