D19 power steering
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Topic: D19 power steering
    Posted: 30 Mar 2011 at 6:03pm
question that I keep meanin' ta ask and keep forgetting. Can I use ATF? Is that better than hydraulic fluid? Thanks, Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2011 at 6:37pm
Use modern day universal hyd fluid.......less leaks and it just works better because it's  thicker viscosity.
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2011 at 7:22pm
For our Fords, which take hydraulic fluid for the powersteering, we have always used ATF just so it is easy to distinguish if it starts leaking, because the sump is so small and that pump burns up so easily...  I see red drops on the ground where one of them sat the night before, I know I need to go chase it down and get it to the shop.  So yes, it is fine to use in Power Steering pumps, just costs a bit more, but comes in small bottles too (another plus).
Hurst
1979 Allis Chalmers 7000
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2011 at 7:22pm
Follow the Dr's orders, but it does say in the original D17 service manual to ask the owner what he has been using. It could have hydraulic fluid, Dexron ATF, or SAE 10 motor oil.
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2011 at 8:33pm
We ended up with everything rebuilt in ours when chasing down the oil foaming problem, which by the way was the pump shaft seal. And when everything is up to snuff  10W or AW32 works great and cold steering effort is much less and responce is quicker than with universal tractor fluid. But as the Dr said when things are worn the tractor fluid helps out with the assist when it's important, warm oil.
