how big of a disk
allis1984 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis1984 Quote  Post ReplyReply Direct Link To This Post Topic: how big of a disk
    Posted: 29 Mar 2011 at 7:56pm
how big of a disk can we pull with our allis 8070 two wheel drive with out being bogged down
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2011 at 8:51pm
A pretty darned big one. I pull a 20 footer with my 7060 and am confident I could go to at least 26 foot. My partner has a 30 footer that he pulls with his FWA Versatile.
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2011 at 9:06pm
I know it could handle a 24 ft with ease, it just depends on how fast you want to drive.
redline View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2011 at 9:35pm
We've pulled a 25 foot Krause with my 7050 quite a few times. It is plenty of disc, but it works all right. We have pulled the same disk with 7060s, a 7580, a 9670 Agco Allis, a 9130 Case IH and a 9190 Deutz-Allis. I hope I get the chance to try my Two Twenty on it this spring, but time always seems limited when it comes to experimenting.
[TUBE]iDQINXwkcps[/TUBE]
Brad(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2011 at 6:53am
Alot depends on soil type and if worked already or not.  We have more trouble pulling in sand that has been worked, as tend to sink and spin.  We used to pull a 27' field cultivator with an underpowered 8050 2wd.  With a good powered 8070, 25-30' would be about right, if you can get traction.
MUM FARMER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MUM FARMER Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2011 at 7:15am
I dont no how  deep or what kind of soil you guys farm you must just be tickiling the ground stay with and 18 to 21 foot thats about all you want unless all your using it for is disking stubble then maybe alittle bigger I pull 21 ft 496 Ih disc with 7in spacing with 8070 mfd or 4W220 in 4th on the low side of power director or 3rd on the hi side low range and that is plenty of disk on plowed ground and no my tractors are not wore out!
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2011 at 7:45am
Much depends on the weight of the disc and the soil type and condition.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
StewartMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote StewartMD Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2011 at 10:04am
Like others have said alot depends on your soil conditions, what type of stubble, are your tires filled with fluid, radials, weights, duals, etc.
8030, 8010, 220, 185, 160, D-17, WD, Unstyled WC, CA, G, 20-35, Gleaner E
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2011 at 11:01am
25ft would  be plenty of disc for most conditions. There would be times you could pull more. But there would be times around here in the mud 21 would be more then enough.
                                                  IG
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2011 at 12:01pm
When people ask about how big ??? something will pull you have to remember that these tractors are 30 to 60 years old, for example you can pulla 5bottom plow with a 190xt and that would be great if you are just making a couple of pass at a plow day day but if you are going to do it all day give the tractor a break and only pull 4. I think that is why some of those tractors got a bad wrap for bad transmissions or rearend when they were just overworked to hard and too long.
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2011 at 6:56pm
I have a 7060 and 7080 both running 210hp and I pull a 26ft DA 2500 at about 6mph in a mostly clay type ground with no trouble at all. The 60 has two inner wheel weights on each side and fluid in 18.4s, the 80 has two wheel weights on each side and no fluid on 20.8s.
This page was generated in 0.095 seconds.
