buyin a tractor
allis1984 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis1984 Quote  Post ReplyReply Direct Link To This Post Topic: buyin a tractor
    Posted: 26 Mar 2011 at 2:33pm
looking for some input here. Narrowed down between a 8050 mfd with power director thats alittle rough or a 8070 two wheel drive with a powershift.  the 8050 needs tires all around and new 3 point links. The 8070 needs nothing but its $5000 more. I dont know what to do.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 2:49pm
What would you be using it for? The FWA and 2 wheel drive would be good for different things.
Dean/MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean/MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 3:01pm
Sounds like the 8050 has a lot of hours on it or has been used hard if it needs work on the 3pt. Power is going to be similar on both but if your pulling in loose dirt the fwa is much better.
HD16,917H,185,7050,8030FWA,8050FWA
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis1984 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 8:16pm
gonna be pulling gravity wagons and do alittle tillage with it.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 8:37pm
I would go with the 8070 as you would not be as likely to buy someones elses problems and for what your doing 2 wheel drive should work just fine.
Good Luck
Randy
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis1984 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 9:07pm
i just need to make up my mind. Thinking i may just have to buy both of them
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 9:13pm
Do you have any pics of them?
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 11:23pm
You'll spend that $5,000 on tires.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis1984 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2011 at 9:00am
rear tires are $1000 each fronts are $340 each
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2011 at 9:19am
That's a great price on tires, I'm guessing 18.4 x 38 rear and 14.9 x28 fronts?
Are they radials?
I just put 20.8R 38s on the rear and 16.9R 26 on the front of my 8070, both apparenly not popular sizes any more, (and when I remembered to subtract the cost of the duals) they were a little over $4,000 mounted.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis1984 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2011 at 11:05am
20.8-38 rears and 14.9-28 fronts
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2011 at 11:12am
Sounds like the 8070 would be the best bet for me.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2011 at 12:49pm
From what I hear, the 8070 would probably be the way for you to go, mostly because the powershift would be nicer for pulling wagons. Do take in mind though, if you plan on doing any PTO work, the 8050 has both 540 and small 1000; the 8070 will have only the large thousand. Darrel
