What is a narrow front CA worth?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Topic: What is a narrow front CA worth?
    Posted: 26 Mar 2011 at 12:48pm
Comes with a 2 bottom pin hitch plow.   Narrow front, front tires look poor.   Rear tires look ok.   Right now owner has a hard time getting it started, but he did have it running for a bit, but it cranks over really slow, and there is a toolbox fabbed up right behind the starter, so the starter isn't so easy to pull out and check it over.   So without it running what is it worth?   Sheetmetal appears to be nice but in another picture, there is two small holes by the air cleaner hole and another hole by the top of the gas tank, so I don't know if the hood was a replacement that came off of a power unit?   Anyways,  here is a picture:
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 12:53pm
2000.00 with the plow is what I would pay...
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 5:21pm
Power Unit Kerosene hood........
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 5:23pm
OK Glenn, give me some schooling here, why do you say that?
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 5:29pm
The power unit had the rectangle tank with the fill hole at the rear of the hood. two small holes in hood are typical of the gasoline starting tank mounting point.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 5:40pm
Any Idea of the serial number? Having a pin hitch and that old style air cleaner it would be early 53 or older I think.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 5:46pm
I didn't have the heart to ask the wife for permission.   And I still have a D19 on the trailer.  It is sold already.   Not running, the guy wanted 800.   Thought it was a steal but I dont' have the time to mess with another or the shed space.   And I already have one tractor sitting outside.   This one was too nice to join it.
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 5:55pm
From what I can see in the picture, it looks like a tractor hood to me Glenn
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 6:03pm
Here is a better picture of the hood.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 6:10pm
It still could be a PU hood if the hole where the oil fill cap comes thru is a oval. And The 2 small holes are behind the Air Cleaner stack. P Units had a tall Stack. I think  the stack support bolted to the hood using the 2 small holes. There should be a round hole close to the rear edge for the PU gas tank. IF it was a dual fuel hood there would be 3 more holes opposite side from the exhaust. 2 small and 1 bigger.
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 6:13pm
Not all PU hoods had an oval hole for a lifting lug. I have two of them that are definately PU hoods that do not.
are genuine." - Mark Twain
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 6:27pm
I learn somethin new everytime I log In. Thanks Green Bay Guy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 6:36pm
$800 was definitely a deal...
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 7:13pm
I don't know how buy you may want to check the hand clutch.  If they don't work it can be pricey unless you bolt them up.
Other than that it looks OK.
Let us know what you do.
Good Luck!
Bill Long
