AC Running Gear Questions
Nathan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan Quote  Post ReplyReply Direct Link To This Post Topic: AC Running Gear Questions
    Posted: 25 Mar 2011 at 8:59pm
 What were the model numbers for the ac running gears?  Did they have serial number tags  if so where was it located at?  thanks nathan
35WC 37WC D-10 D-12 D-14 D-15 D-17series 1 (2)D-17IV D-19 CA RC Unstyled WF GLEANER E 416H 314H 712H 716H
Bill (E.C.MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill (E.C.MO) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 10:14pm
Nathan,
Norm Swinford lists 7 models of running gears in his AC Farm Equipment book:
305, 405, 505, 605, 701, 1001 plus a model 500 which is a 5th wheel steer wagon.  Though not listed in the book, I have a 501 (five ton) and a 601 (six ton).  There may be other models also (?).  The model numbers are typically stencil-type numerals located on the right-rear corner brace of the frame.
They did use serial number tags.  The ones I have seen are always found on the rear-facing end of the back crossmember.  Here's a picture, the s/n plate is just to the right of the "Allis Chalmers" decal:
A-C's currently on the farm: B, CA, 2 D-17 D's, One Eighty, ass't implements.
