4230 fuel
murdoc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote murdoc Quote  Post ReplyReply Direct Link To This Post Topic: 4230 fuel
    Posted: 25 Mar 2011 at 8:56pm
anybody got any ideas on how to make a john deere 4230 not burn so much fuel
i got a 806 international that is 3 time better on fuel than that deere and power than that deere  too
Edited by murdoc - 25 Mar 2011 at 8:57pm
Mike NEIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike NEIN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 9:12pm
I guess you could take it to the scrap yard and get an orange one...Lol couldn't resist.
boscoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boscoe Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 9:17pm
WOW ........i have seen it all now.
1959 D 17 gas , 1964 190 gas, 1965 190xt gas AC 4bottom slat plow, 6 row 30in #72 planter Im not getting bigger my cloths are just getting smaller.
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 9:17pm
Can't help but neighbor had a late 4020 and bought a new 4230, 4020 took half the fuel and did the same work, just not as nice to drive.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 9:19pm
prolly something wrong with it. sounds like it needs a tune-up. pump, injectors and valve adjust. The 2 tractors are similar in many aspects, 404cid jd, 407 ih, roosa pumps, dm on jd, db on ih, jd 100 rated hp, 806 95rated. Does either one have an added turbo? both are good tractors, and should be reasonably efficient, but a 190XT/200 will do more work on even less fuel.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 9:45pm
Neighbor runs a 4030 and also complains about it's thirst for fuel.  Nature of the beast I guess!  Haven't been able to convince him to buy ACs yet...
Post Options Post Options   Thanks (0) Thanks(0)   Quote murdoc Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 8:30am
boscoe     I don't think you can contribute to this discussion seeing you don't have a diesel tractor.
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 9:11am
CLean or replace the air filter, tune up (pump & injectors) & oil change. What are the rear tires like? Switch to radials on the rear. How is it weighted?  Trade up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote murdoc Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 9:12am
what would you trade up to
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 9:49pm
210 or 220 or 7030 or 7040. All awesome tractors :-)
Wink
I am a Russian Bot
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 10:42pm
a 4230 is verry good at turning fuel into heat and noise, that's what they are known for.
I should not post that, but it's true.  Just about all my tractors that do the work are JD, but there's no love here for a 4230, I grew up driveing one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 11:10pm
Depends on how much you can afford and what your taste are. 4430 if you have to have green or save a bundle and get something like a 7045 or for about the same as the 4430 get an 8030 instead and get a much better tractor.
