220 Front Weights Wanted
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Topic: 220 Front Weights Wanted
    Posted: 25 Mar 2011 at 1:20pm
Hello all,
Looking for a full set of Allis front weights for a Two-Twenty, does anyone have a set around central Nebraska, or a set from another tractor that would work.  I don't know if the Two-Ten is the same or not, the D-21 set is different, so I don't know.  But if anyone does, please let me know.  Thanks in advance!
Still in use:
dpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpower Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 1:42pm
andy gubbels had a set of these for sale. He is located in Northeast Nebraska.
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 3:04pm
In case you were not aware of it there is two ways to go, suitcase weights & bracket or the big starter weight and add on slabs. I think the suitcase weights were used more on the 210 than the 220 for unknown reason.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2011 at 7:48am
Thanks for the info, I emailed Andrew.  Was the suitcase weight opion a factor option, or somthing that worked, becasue the bolt pattern was the same.
Thanks again!
Still in use:
Chad (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2011 at 1:13pm
The suitcase weights must have been an option from the factory or dealer installed.  My 220 had the bracket "marks" on the frame, so I put a set back on it.  Butch is probably correct that more 210s had the suitcase style weights than 220s.  Chad
220 3-190XT 2-D19d D19g 5-D17 UC 3-WC 2-WD 3-WD45 CA C H3 7-AllCrops 14-plows 3-Gleaners Lawnmowers SC-equipment
