7060 spindle arm removal
SIMPLICITY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Topic: 7060 spindle arm removal
    Posted: 24 Mar 2011 at 9:14pm
 looking for some tips to remove front axle spindle arms on a 7060.
  i am guessing would it be better to leave the spindle support arm in the tube ? and i know the arm needs to come up cuz the axle has a woodruff key in it.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2011 at 9:54pm
Remove wheel. remove snap ring. Get a 5 gallon bucket of cold water. Heat the arm with a rose bud to red hot and douse with the 5 gallons of water. Tap off or pull off arm. When you put it back together heat the arm red hot again and, using a pliers or whatever, set the arm back on the shaft (tapping it down with a hammer to it's proper location) and let it cool on it's own so it shrinks tight otherwise it will come lose later and ruin the shaft and arm.
Wink
I am a Russian Bot
Carl(NWWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 1:06pm
do it that way, i just did it about a month ago, worked great. I'd recommend having two torches with the rose bud, goes a alot quicker and easier. Also, pull the wheel off,put chunks of wood under the frame rail on top of the axel to stop the play, and put a jack underneath the spindle to keep pressure on it. get the arm red hot, dump the 5 gallon pail of water on it, then use a 3lbs or 5lbs hammer and hit it off from the bottom side. Then to put it back on i got it red hot again, and used a pipe with a diameter just bigger then the hole on the arm so it didnt smash it smaller, tapped it on with a hammer. let it cool. Works really good!
