Parts for a 844 ci engine ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: Parts for a 844 ci engine ???
    Posted: 24 Mar 2011 at 5:35pm
What parts are still avaliable for these engines ? I seen you can get overhaul kits ; what about cranks etc ? Got a new project brewing ;
Edited by DougG - 25 Mar 2011 at 11:34am
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2011 at 6:16pm
I have some used 844 parts but no more crankshaft.
big al View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote big al Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2011 at 10:21pm
i am rebuiding one as we speek,you might be able to get a new crank from fiat,the last time i heard about $4500.00
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 5:43am
Reported
scott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 6:26am
Would an 844 bolt in where a 426 had sat?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 11:26am
I have found out the old BIG AL engines had a counterweighted crank ;thats the one that broke ; then AC put out a new version in about   1975  ; anyone know the differences ? I believe I could have one made for $4500 ; also anyone know if the BIG AL version is different than the engine for scrapers and crawlers ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote big al Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 11:55pm
the cranks broke off at the front snout do to prolonged tortional vibrations.allis tried to correct this by drilling the crank to accept a long dampner bolt to keep the nose of the crank in compression.then they induction hardened the nose,then they went to a 6 counter weight crank(instead of 12) to lighten the rotating mass,finally they went to a snub nose as used in the 6138.all the above improvements have differant part #s.note: cummins also had this problem (335)and went to the snub nose.
This page was generated in 0.219 seconds.
