Need a spark plug recommendation
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Topic: Need a spark plug recommendation
    Posted: 24 Mar 2011 at 12:04pm
for a WD.  Valve seals leak badly. Engine smokes on hillsides. Need to keep using tractor for a couple weeks.  What mfg & part # would be less likely to foul?
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2011 at 12:20pm
Autolite #295 & STP!
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2011 at 12:24pm
Get the spark plug extenders, they have a small hole toward the piston, oil cannt get to the plug and foul it.    I have a set in my toolbox for just such occasions.  Got em at an auto parts store.   Maybe the name was Nofoul.    Your plug wont foul with em, power may be down and it will burn the oil now.   HTH
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2011 at 12:52pm
I have good luck with autolite 303.
KGood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2011 at 1:04pm
Do what skip said use the nonfouler. I've seen them work on a wc that would spit oil on your shirt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2011 at 1:05pm
Sorry Skip I overlooked capitalizing your name.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2011 at 1:08pm
WD doesn't have valve seals. Just get the next hotter plug than what is recommended if you have oil fouling or do like Skip says.
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2011 at 8:04pm
Marion Klutzke of Lafayette, In. told me to use LM 49's, a mower plug, and they sure have worked for me!!!!
