wd45d tear down transmission question
Tony Elo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Elo Quote  Post ReplyReply Direct Link To This Post Topic: wd45d tear down transmission question
    Posted: 23 Mar 2011 at 8:56pm
I am working on a wd45d.I have the pinion gear out of the differential.when i took it apart,the bushings that go on the pinion shaft in the transmission have these very small holes with what looks like a small rivet in them.What is their purpose? Of course I dropped one into the bottom of the transmission.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2011 at 9:10pm
The pins are to keep the bushing pined to shaft. They keep the bushings from spinning on shaft.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Elo Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2011 at 9:13pm
that makes sense,if i can't find the one i dropped,i have a tractor for parts i can rob one out of
This page was generated in 0.477 seconds.
