Pump Question
B Litke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B Litke Quote  Post ReplyReply Direct Link To This Post Topic: Pump Question
    Posted: 23 Mar 2011 at 9:34am
  Will the hydraulic pump off of a Gleaner E combine work to lift a scissor  lift with 5' dia on a dump trailer?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2011 at 10:01am
I assume you mean 5" cylinder. Just about any pump will work, the problems are volume and pressure. The pump will determine volume and your relief on you valve will limit pressure. A large volume cylinder with a low volume pump will work but might take forever.
