AC HD 16 DOSER TOUQURE CONVERTER - diesel fuel ? |
DougG
Topic: AC HD 16 DOSER TOUQURE CONVERTER - diesel fuel ?Posted: 21 Mar 2011 at 7:26pm |
I was just on a Heavy Equipment forum and they were talking of diesel fuel running thru the tourque converter on a HD 16 ? Howd that work ??
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4840 |
Posted: 21 Mar 2011 at 8:00pm |
I don't know a lot about torque converters but they did use diesel as the fluid in some of the early ones on dozers.Caterpillar had problems with them so they changed to using oil in later ones in Caterpillar D8 any way.
HD6 Merv
Joined: 03 Aug 2010 Location: New Zealand Points: 500 |
Posted: 22 Mar 2011 at 12:20am |
Allis Chalmers were the first to use a torque converter in a crawler tractor. It was a 3 stage twin disc unit in the HD14C. and used diesel fuel as its drive fluid.
Next came the HD19 and 15 then the 20, and early HD16s and 21s.
Later HD16AC and DC models and HD21A models changed to a single stage oil filled converter.
Merv
doc mopar
Posted: 01 Apr 2012 at 9:34pm |
i have hd16 i rebuilt torque convertor in years ago that runs on diesel fuel if anyone tries to rebuild one be very carful taking it apart the inside is made of carbon and will break very easy just wanted to let everyone know hope this helps |
Ages Cat
Joined: 12 Sep 2009 Location: Hutchinson, MN Points: 700 |
Posted: 03 Apr 2012 at 10:32am |
Operators have told me that as long as the tank was full of fuel to absorb the heat you were OK, With low fuel late in the work day, the torque converter temperature would rise dramatically.
