OT-Cummins exhaust
Eric[IL] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Topic: OT-Cummins exhaust
    Posted: 21 Mar 2011 at 5:57pm
I had a Dodge 96' cummins 5.9L swapped into my 2000 F350 6spd crewcab dually.  The 7.3L was getting tired at 272,000 miles.  I am most impressed with the pulling power of the cummins 12V coupled to the 6speed tranny & 4.10 gears.  My engine swap mechanic had a 4" straight SS exhaust put on it, but I will need some type of muffer.  Don't get me wrong, I think it sounds cool hearing the turbo spool up through the gears.  In 6th gear, at 70mph it is quiet, but at the 55-60mph there is an exhaust drone that will drive me to wearing ear muffs.  Its like a pressure buildup on my hearing.  What type of fow through muffler should I have the exhaust shop put into this for more reasonable quieter sound?
allis6080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis6080 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 6:55pm
were does it exit at? i have an 01 dodge with 4" straight through with no muffler and exits out the back corner and i have not drone at all.
6060 s\n 5016
1947 JD B
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 8:46pm
Banks Monster exhaust, nice tone, but no drone
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
chllngr528 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chllngr528 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 8:58pm
MBRP or silverline is what I would go with. I'm rocking 5 inch MBRP with a muffler.
I actually just put my muffler back on because I was afraid one of these mass cops were going to break their neck looking at my truck as I drove by.
By the way, I'm glad to see another de-stroked ford
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 9:02pm
The exhaust is 4" from the turbo back.  It goes all the way over the rear axle then exits at the rear corner.  I'll try to get a pic tomorrow.  It is straight for a good length(8-9'??) from just below the front of the crewcab to the rear axle (8'bed) before it vertically bends up and over the axle.  Then it has a 90 degree horizontal bend around the back of the duals.  Would any additional bends in the 8-9' straight area help reduce or remove a drone?  Or, would placing a 36" long flow through glass pack do any justice?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 9:04pm
This will make it sound GOOD!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote chllngr528 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 9:10pm
Is that the new stainless hopper for a planter I read about? lol I do believe thats the biggest stack I have ever seen. What would anyone ever put that on?
Edited by chllngr528 - 21 Mar 2011 at 9:11pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 9:12pm
I guess they can go on anything, the question is does it have enough sack to fill'em!!!
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 9:17pm
That big stack should funnel alot of water down the pipe if you leave it out on a rain storm.
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 9:51pm
Banks is garbage....I redid the stacks on my buddies Cummins and it was LOUD but he wanted to quiet it down with having a baby recently so I put an MBRP muffler on it....same as my 6.0 has....great sound, but very livable to drive.....and they arent that expensive.
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2011 at 3:07pm
just imagine the "flapper caps" on those stacks!!
Have never had any problems with any banks parts around here.
This page was generated in 0.773 seconds.
