AC 7060 vs IH 1586
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Topic: AC 7060 vs IH 1586
    Posted: 21 Mar 2011 at 1:13pm
What would you choose? I would choose the 1586 "better cab view, quiter cab, better engine, shorter hood and no muffler and air intake to try to look around! The TA is a plus but just as good as the PD on a allis, More cab room. Dont get me wrong I like the 7000 series but "I" would pick 1586...
Edited by R.W - 21 Mar 2011 at 5:24pm
Brad(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 1:43pm
I thought the 1586 had a 3 speed or 4 speed trans (plus the torque), that's why they sold so cheap.  Not familiar with IH, but we have a 7060.  It is/was a great tractor, but liked to drink the fuel.  I would think the 7060's transmission would be way better than the 1586's.  Powershift would have 12 forward gears, and power director would have 20 forward. IH would have 6 or 8. They are both rock solid transmissions IMHO.  Wouldn't the IH have the goofy suicide style doors?  Hard to get in and out of, but bigger cab.  I should know a little about the IH, as my neighbor has well over 100 of them.
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 1:52pm
Yes they do have suicide doors, and those transmission weren't that great, hard to shift, and less speeds than the 7060.  The TA's were great if they were not used, a different story if they were.  I H did have a good diesel engine, that started well and was easy to get a lot of power out of.
KGood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 2:18pm
The technology in a 7060 by far would exceed a 1586. The best part of the IH is the engine.
cms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cms Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 2:50pm
The 1586 is a good tractor but they ride very rough going down the road. They are very hard to get in an out of for an older person.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 2:51pm
just because a tractor is popular doesn't make it a great tractor. 15's had problems with the planetaries, and axles, plus the speed transmission is only 3 speed. A 7060 would be a far better tractor, and so would a 4640.
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 3:11pm
Originally posted by R.W R.W wrote:
What would you choose? I would choose the 1586 "better cab view, quiter cab, better trans, shorter hood and no muffler and air intake to try to look around! The TA is a plus but just as good as the PD on a allis, More cab room. Dont get me wrong I like the 7000 series but "I" would pick 1586...
WOWA .. 1586 quiater? no way The 7000 series were the quietest tractors of the day ....
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
BLee Mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BLee Mn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 4:30pm
Better cab on a IH?????  OH MY, if i bought a IH,  1ST thing id do is cut the darn cab off!  Stupid doors, poor layout.  Ih was always way behind in the cab department
Cowboy UP
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 5:22pm
Ok yall are makeing me feel bad... We have a 1586 and a 7045 and I would pick the 15's cab. I think its quiter and It has most of the foam riped out of it and I think the cab has better view and we only had ta trouble once and that was along time ago! I think the doors and cab is not that bad to get into "but im only 13". The gears arent the best but you still have the ta to use. Ours is turned up about 200hp and that tractor can PULL! But this is just my oppion and most of you will say the 7060 just because its orange! lol
MikeB (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeB (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 5:34pm
 Good comparison.
Per Nebraska tests
1586 IH 161.55HP@2500 RPM - 10.58 gal per hour - 79.0 db(A)
7060 AC 161.51HP@2300 RPM - 10.17 gal per hour - 77.5 db(A) Bwn Belly 7060 78.5
4640 JD 156.30HP@2200 RPM - 10.01 gal per hour - 77.5 db(A)
2-155WFE 157.73HP@2200 RPM - 10.43 gal per hour - 80.0 db(A)
2390 JIC 160.52HP@2100 RPM - 10.56 gal per hour - 77.0 db(A)
TW30 Ford 163.28HP@2200 RPM - 10.35 gal per hour - 82.0 db(A)
 Also note that A-C, JD, and Case used multiple disc wet clutches while
IH, White Farm, and Ford choose a single disk dry clutch for their manual transmissions.
Deere and Allis offered powershift transmissions and over 50% of their customers ordered them that way.
My neighbors with lots of Iron Horse JD's use their 1586 as an auger tractors. I should not spout off as I never had the pleasure of owning or operating a 1586 or 2390 Case.
Case, Allis, and Deere also offered 180 hp tractors. I always wondered why IH didn't as I know they had the engine for it. Always made me skeptical that their powertrain was not strong enough.
Also in the above tests in would appear that John Deere won the fuel economy tests, but one always has to keep in mind that everything they tested at Nebraska got better fuel efficiency than their actual production tractors. I'm not saying they would cheat or anything wink wink> John Deere engineer's will concentrate on the fuel settings.
Cab visibility your right I like the IH, but the short wheel base gave them a terrible ride.
The John Deere Bostrum seat was so sweet with the hydraulic accumulators controling
the up down side to side for and aft movements. Also to bad A-C hid the throttle behind the steering wheel on the dash, they had the side console so right with the hundred series tractors.
Edited by MikeB (SD) - 21 Mar 2011 at 5:35pm
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 5:42pm
Well, you should be feeling kinda bad asking a question like that on the "Forum", last I knew, we all bleed Orange and IH/JD/etc are like swear word's around here, only kiddin' my friend, do you need my address to have that 7045 sent to my house, I would really like it in my barn [ NO IH's on this property!]
Chris WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris WI Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 6:17pm
all color opinions aside the cab on a 1586 has NO LEG ROOM!!!  a 7000 ser may be tight in the shoulder area but for a tall guy 86 ser. cabs are a leg cramp waiting to happen! I am 6ft 7in I know.
MI8050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MI8050 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 7:09pm
1586's are too slow with less gears and had the planetary rears, sort of an orphan 86 series.  I had a 986 and have a 786, the 86's don't ride that bad, the 986 had ok leg room and I'm 6'3".  I always have liked the 7000 series and thought they were advanced for their time, my 8050 has plenty of cab.  IH hit the 200hp mark with the 5488 (not officially but certainly on any dyno, and they held up to it.  I hate to say it but you don't see 5488's repowered, only 8070's.  I like 'em all!!!!!
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 9:44pm
One reason you see 8070s repowered is they're worth it. It's not a cheap proposition to repower a tractor these days so if your going to do it you better do it to a tractor that will last. LOL!
All the 88 series were few and far between and I think I've seen more "restored" and setting in a shed than I ever saw in the field.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 9:58pm
The 88's were definitely an advancement over the 66 and 86 series, but as Dave said they are few and far between and left a lot to be desired.  Its not real common to see 8070s repowered from my perspective, and I know of an 8050 that is running at 215 hp  and its holding together so I don't see a real problem there.  A lot of the 414 and 436 IH motors have been replaced with a 466 because they did not hold together so I don't think IH is really any farther ahead in that department.
boscoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boscoe Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 10:00pm
had a 1586, sold it 8 yrs ago T/A went out right before i sold it so $2500 for that , 3 gears for shifting, terrible, rough ride because it is soo short weel base , hard to get in and out of ,just about tumbled many times, only my opinion. 7060 never had one , so no idea.
1959 D 17 gas , 1964 190 gas, 1965 190xt gas AC 4bottom slat plow, 6 row 30in #72 planter Im not getting bigger my cloths are just getting smaller.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 10:08pm
86 IH good cab visibility? REALLY??? hook up to the 3pt, or drawbar in one? There is a mirror because you can't even see the darn hitch!! I did get good at using that mirror though. Plenty of IH's repowered with dime-a-dozen DT466 truck motors. Why put a cummins in one when these motors are everywhere, and bolt in. 400 series is a good engine, but they do have their problems too! Ed.
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 10:16pm
7000 series was way ahead of any company at the time, exspecially with the black bellies. I prefer allis because of the leg room. The visibility is probably about the same or not better with 7000 series than the 86 series IH, lay out of the cab is important, and Allis had a heck of a good transmission either being a PD or a PS. Yes the cab is a a little narrow on the 7000's, but the smaller the cab is the closer the ladies have to sit next to ya!
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2011 at 4:14am
the IH's are shorter and rougher riding, the tranny's sometimes would lock in forward and reverse, and if ya let the clutch out it would shell the whole tranny! my neighbor had that happen twice!
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2011 at 7:20am
Can't resist. The long list of poor IH design once again. The front axle is high wear and used way to many unnecessary parts. Same with the 3-point hitch. The engines, although you can get good power of them, are not good luggers stock and run at very high RPM so are noisy. The dry clutch is by nature high maintenance and it not unusual for the clutch splines shuck out requiring the replacement of the IPTO splined shaft also. Do I need to mention the TA whether it's the standard or the mechanical diode makes little difference. While you're into these areas you might as well replace the hydraulic pumps as they do not hold up well. These IH 66 and 86 series are notorious for there transmission, rear end and rear axle problems. Then you have the park lock that is so easy to bust cause the tiniest roll while you put it in park will take it out. Make sure you are stopped completely before putting in park. Brakes in most models are very poor and require maintenance and even after repair many times are only moderately good brakes. The PTO if you use it much will eventually give trouble. Sometimes a tiny little roll pin will brake and require a tear down of the PTO. The shifting is absolute junk and high maintenance. Try to pull a starter on a 1566 once. It ain't fun. All this and I'm sure I forgot things. Creature comforts leave a bit to be desired like the location of controls, cab doors, rear visibility and rough riding although I never thought they rode that bad but my 7050 rides better.
Wink
I am a Russian Bot
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2011 at 7:36am
Some of my best memories were made behind the wheel of dad's 7045.  I'm with Chris/CT, just send it on over.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2011 at 7:43am
Well yall seem to have some terible things to say about the 1586... But ours has been running and working HARD for years and I dont think we had to do any real maintence except oil changes. It has less gears because of the very large diff, and gears "wich me and my dad have heard of few giving out! I'v never had any problem with hooking up the 3point or drawbar. It has pulled a 21" finish tool most of its life and had no real problems! And a good set of front weights and rear radials will smooth out the ride as ours rides as good or beater than our 7045!
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2011 at 8:25am
Don't take it too hard RW, this is an Allis site and your question was just itching for a lively debate. That said, I worked for 4 years at an Allis shop as a mechanic and for 4 years in the parts department of an IH shop and IMHO the IH's take more parts. I did notice that more IH people take pride in their tractor than Allis customers as they would spend way more money, like $5,000 to repair a Super MTA and $7,000 to repair a 504. That was over 10 years ago. I never saw an Allis farmer do that with a WD45 or D15. Those were repair bills not restoration bills. But other than the longevity of the engines the Allis 7000 series to me is quite a bit better tractor with a lot worse customer support overall than IH. There are real good Allis dealers out there but way too often they are 50 miles or more away. That's the biggest thing Both Deere and IH/CaseIH owners have over Allis owners. That does ensure an eventual collapse of Allis tractors being used on farms thanks to Deutz and now AGCO management so your IH will still come on top in the end.
Wink
I am a Russian Bot
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2011 at 10:29am
At 6ft 7in you aint guna get much leg room in any tractor and all you halfto do is raise the seat it the 1586.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2011 at 10:38am
Just some videos on the 86 series...
[TUBE]0XuqY5LuzJU[/TUBE]
[TUBE]Lpa33ROU_oM[/TUBE]
Byron WC in SW Wi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Byron WC in SW Wi Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2011 at 10:41am
Plowed with 7060 and disked/hauled manure with 1086.  Didn't know enough back then but I liked them both.  One thing I'll say, (being tall), is you can't just raise seat as you end up bonking your head on the roof of any tractor.
Reeseholler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reeseholler Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2011 at 10:55am
I never really cared too much for the 86 series. IH was on the downward spiral. I much prefer the 66 series. It's like all tractors. You get good ones and bad ones. You could have 3 of the same model and they'd all have different personalities. Our fords are the farm are split at least once a winter to have internal work done. They take time to fix the issue not the problem and it ends up torn apart again. Poor operation costs a lot in repairs...
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2011 at 3:29pm
I do like watching these old films no matter the color. I smiled when they referred to their Control Center and to John Deere's cab. Just cab and not Sound Gard cab.
Wink
I am a Russian Bot
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2011 at 3:49pm
X 2
Mark
GTH-L Simplicity
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2011 at 3:54pm
The reason you cant see is because of that "kids seat"! I spent a many years rideing on that shelf when I was little!
This page was generated in 0.091 seconds.
