Front mounted hydraulic pump
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Topic: Front mounted hydraulic pump
    Posted: 20 Mar 2011 at 4:11pm
on a D19. Question is where do I start? I know nothing about parts, pieces, where to buy, etc. Is it one unit to purchase or is it home made with many parts fabbed up? Thanks, Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2011 at 6:22pm
Dana, can't help you on that one, but I have a D19 here that had a front pump on at one time and it got taken off before I bought it.   There is a diverter valve on the left front right by the tractor's pump which switched from the front pump to the bottom pump.   Once I get the tractor running and see if the lower pump is alright, I may take all of that off and if you need it, we can work something out.    Just would be happy to see someone use it.   I just hope I don't end up with the same thing as yours when I get it up and going.   Needs a clutch first.   Hope to dive into it, in the next couple weekends.
E7018 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote E7018 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2011 at 8:20pm
Here is a link to the pump and drive I made for a D17 that I put a 301 engine in;
http://www.allischalmers.com/new/forum/uploads/2035/D17_11.JPG
I lengthened the frame for the engine so I added enough for a front pump.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2011 at 10:28pm
Dana here is what the pump looks like.
And here is the T to connect it to the belly pump, mounted right in front of the clutch pedal.
ALLIS EXPRESS!
This year:
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2011 at 10:35pm
That looks like a Parker/Hanafin that was power steering pump on a 79 INT semi cabover I had.Was on the back of an 8V92TA.
Edited by Steve M C/IL - 20 Mar 2011 at 10:35pm
Jim Hancock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 12:15am
Hey E7018, Would you mind posting a pic of your D17 with the 301 in it, please? That sounds like something to see and hear! Thanks. Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 6:14am
The diverter valve will not be used in this case because the original pump will be gone.
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 6:26am
Dana, check with Force America, 800-789-7711 and ask for Tom Kaufman, I got a front mounted pump for my D17, he knew what i wanted and had all the parts to make it work. Tell him Randy told you to call!
Post Options Post Options   Thanks (0) Thanks(0)   Quote E7018 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 7:44am
I did when we got it out;
http://www.allischalmers.com/new/forum/uploads/2035/D17_7.JPG
Now, I need to get a couple gallons of orange paint splashed on it.
If you are in Oklahoma, my second choice of an engine was there. I found one closer. A fellow had a combine he was saving for the motor.
Glenn (NJ) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glenn (NJ) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 5:33pm
I have a front pump and drive shaft from a D-19 . Never got the tubing or diverter valve.  I think I paid a $100 for it when I was going to try and put it on a D-17. I have no time for that project and would like to get my money out of it.   It's at my place over in Jefferson, NY or could put it in the mail.
bwp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bwp Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 5:47pm
Dana,
Here are some pictures of the front mounted pump that I put on my D19.  I would try to get an original one if you can, then you do not have to cut any sheet metal from the front end of the tractor.  Wish I would of known where to get an original factory mounted pump for mine.  Anyway, this one turned at pretty good.  Let me know if you need any measurements.  Good luck.
Brad
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 6:34pm
What pump (Brand, GPM etc.) is that and where did you get?
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2011 at 6:05am
Wow thanks for the info. Glenn can I have a telephone number please?
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2011 at 9:46am
OK guys with a front mounted pump and with my belly pump removed, is my belly compartment/sump still used as the oil reservoir?
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2011 at 11:13am
Yes, use your existing sump for the oil resivour.    One caveat here,   the small pump behind the cowl like Glenn says he has is a very small volumn pump.  I dont think it was meant to take the place of the main hyd pump, but to serve as make up oil when the main pump wasnt pumping, like with the clutch pedal down.  What it did was give you indepent hydralics.  I have a D19 gas that has the front pump, the tractor had a loader on it most of its life, the guy who had it feed cattle and the D19 loaded the feed wagon.   What I would do is put the main pump back in and leave out the cam followers on the bad lobes, then use the front pump too.  that way you you wont be overloadiing the front pump.    Hopefully Glenn has the crank pulley adapter that goes with the pump, they are spendy, and Im not sure you can buy one anymore.      Good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2011 at 11:20am
Skip I did a "rough" test with mine.....clutch down, plow up in 6 seconds, clutch up plow up in 3 seconds.  It appears that they pump the same volume...but that little guy sure looks small! I think it runs faster though.....
ALLIS EXPRESS!
This year:
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2011 at 12:14pm
Glenn, If for some reason (I can't imagine what) Dana passes on your offer, I would be interested; I live only about 15 miles from Jefferson.
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2011 at 12:50pm
Yes, I am getting the pump and mounts from Glenn. If I am only going to lift a cylendar on the haybine and when baling to aim the kicker I suppose the front pump would be sufficient? Thanks, Dana
bwp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bwp Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2011 at 5:08pm
Fixer,
The pump is a MTE model C315M-23. It is an older model. I am not sure of the GPM but it handles the loader pretty well. I really can't complain because I got it for free. Have a good friend who gave it to me. He was a foreman at a paper plate factory. The factory had a surplus and he got to take a few home. I think he said it was run off a motor and it supplied a large industrial press.
Brad
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2011 at 7:14pm
Thanks for the info Brad
I'm looking to set up a loader pump and I will dig around and see if I can do anything with those numbers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2011 at 7:19pm
I don't care if it is a small pump and only matches the original pump volume/output, it's LIVE !!! and works with the foot clutch pushed down!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2011 at 7:47pm
Would anyone here have any manual, or diagrams as how to plumb? Did Allis have directions? Thanks! Dana
This page was generated in 0.176 seconds.
