Penetrating oils
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Topic: Penetrating oils
    Posted: 20 Mar 2011 at 3:33pm
I've known about this and have been using it for a while and have seen reference to it before. The results are interesting.
 Machinist's Workshop did a test of penetrating oils where they measured the force required in a standard test
to loosen rusty test devices. The results reported were interesting.
The lower the number of pounds the better. Mighty interesting results for acetone and automatic transmission
fluid!
Penetrating oil . Average load .. Price per fluid ounce
None ............ ..... 516 pounds .
WD-40 ............ .. 238 pounds .. $0.25
PB Blaster ......... 214 pounds .. $0.35
Liquid Wrench ... 127 pounds .. $0.21
Kano Kroil ........ 106 pounds .. $0.75
ATF-Acetone mix.. 53 pounds .. $0.10
The ATF-Acetone mix was a 50/50 mix (1 to 1 ratio)
_________________________________
John Kallend
Professor and Associate Dean
Armour College of Engineering, IIT
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2011 at 3:44pm
We used Kano Kroil for years in an industrial environment with great results.  I had not heard of the transmission fluid and acetone mix until a couple of years ago.  It is an interesting result that the cheapest is the best penetrant.        Tim
48AC/WD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 48AC/WD Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2011 at 3:47pm
Looks like the parts store just lost me, lol going to have to try that ATF and Acetone mix, I use ATF in my partswasher to neutralize the bite a little bit, I use "Purple Power" in it, if you put that stuff in straight, it will eat the paint outta the tank, ask me how i know and why my filter was plugged with paint slime, LOL! The stuff is incredible though!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 48AC/WD Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2011 at 3:51pm
Darn computer double posted, sorry guys.
Edited by 48AC/WD - 20 Mar 2011 at 4:03pm
Dnoym N. S. Can. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2011 at 4:01pm
ATF-Acetone   50/50 mix
been use-ding it to free stuff up
it work
i don`t think that the acetone
will eat metal because it come
in a steel can    i free up 2 engine
this winter with it and have not
started them yet took 2 to 4 week
to free them up
rock them once a week let set
till next week and rock again
now i can turn them over with
crank
and i did suggested  it a couple of time`s
WD-40 . 238 pounds never cared
for this one
PB Blaster 214 pounds
smell to much JMHO
B:-)      Dnoym
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2011 at 4:09pm
I've got an old Twin City parts tractor sitting out back that had been stuck for years. I loaded the cylinders with the 50/50 mix before Christmas and it freed up this week and just rolls over nice on the crank now.
