hd11ep
hd16b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hd16b Quote  Post ReplyReply Direct Link To This Post Topic: hd11ep
    Posted: 20 Mar 2011 at 8:26am
I have a hd11ep and was wondering if it was possible to put the segment style sprocket off of a 11b on the 11ep.Have always been told that it would not work.
AC Mel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Mel Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2011 at 12:07pm
Yes, It should be doable . The HD11EP and the HD11 series B use the same undercarrige. We're planning on doing that when we have time to work on our  HD11EP. Some of the early HD11Es (not powershift) had the smaller undercarrige. But EPs should be compatible with the series B.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2011 at 12:29pm
Many thing are possible , I put D5 track on my D6 and used the D5 segmented sprocket ring which I welded to the D6 sprocket spokes after cutting old D6 teeth off.
 Was easier to find D5 track than older D6. Everything else interchanged .
HD6 Merv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2011 at 12:27am
I have seen Cat D5 track gear with 6.91 pitch fitted to a HD11. Same rollers were used; and the guy had a adapter ring made up to weld to the allis spokes that took the cat segments. HD11 sries B rim should be adaptable to a 11EP or just use a B sprocket.
