wd-45 headlamp upgrade
Ball View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ball Quote  Post ReplyReply Direct Link To This Post Topic: wd-45 headlamp upgrade
    Posted: 19 Mar 2011 at 10:38am
I thought I might like to go overboard on the headlights on my wd-45, wanted to keep the original housing , drop in a seal beal , 12 volt, . So far I can find 4  1/2 inch , too small and 5 1/2  inch , too big.
Any 5 inch seal beams out there?
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2011 at 11:21am
 If  reflectors  are  good  just  use a 12 V bulb to brighten things  up. Tony
dannyraddatz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dannyraddatz Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2011 at 11:59am
I found a NAPA bulb #LMP1143 for the 12 volt conversion. I used the 4 1/2" NAPA lamp #LMP4419 in my tractor. To make it work you have to buy 1/4" fuel line and cut it down the center on one side only, wrap it around the headlight and insert in the housing, install outer clamp and your done.
Danny
Edited by dannyraddatz - 19 Mar 2011 at 12:00pm
Danny Raddatz
Ball View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ball Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2011 at 12:23pm
very good ,   thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2011 at 3:03pm
If the reflectors are not good have them chrome plated. I did that on my Oliver 60 and with 12v bulbs, it doesn't really need anything else.
