D17 wide front swap
roadrunner(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote roadrunner(IN) Quote  Post ReplyReply Direct Link To This Post Topic: D17 wide front swap
    Posted: 18 Mar 2011 at 4:59pm
Is the wide front the same on series III and series IV? Looking at a series III parts tractor. My series IV has a narrow front and would like to switch. Second question is will a 415 loader work fine with my series IV by plugging hydraulics into tractor, instead of front pump?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2011 at 5:39pm
Series III and IV had the same wide front.  I'm looking for one as well to replace the diesel Series I/II wide front that was adapted to my Series III gas.  It originally was a NF.
Should be no problem running your loader through the remotes assuming your Series IV is equipped with two remotes (mine only has one).  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
This page was generated in 0.248 seconds.
