Need diesel engine oil advice
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Topic: Need diesel engine oil advice
    Posted: 17 Mar 2011 at 6:36pm
What is good year around engine oil for a 6060 diesel tractor? I've been running SAE 30 like the owners manual says but there is probably more modern formulations out there now, advice?
Larry B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry B Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2011 at 7:13pm
i have a 7045, dt160, and a jd4440 and use rotella 15-40 in all of them year around
powertech84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2011 at 7:29pm
I like to use a 5w30 in smaller diesel engines. It helps them crank and start alot easier, especialy in winter. Being from minnesota, and not the southern part of the country, you'd be fine to run it year round.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2011 at 7:31pm
15 / 40 Rotella in this area year round in all the off road and on road diesels.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2011 at 8:05am
Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2011 at 3:10pm
There is a 10w-30 diesel rated oil that the new Ford built Powerstrokes use.
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2011 at 3:23pm
We ran 15/40 in our 6060
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2011 at 5:02pm
The Rotella oil is a good choice and, if you don't want to change oil very often, the Mobil 1 turbo diesel 5w-40 oil is another good choice------especially if you start in cold weather.
http://www.mobiloil.com/USA-English/MotorOil/Oils/Mobil_1_Turbo_Diesel_Truck_5W-40.aspx
Edited by 427435 - 19 Mar 2011 at 5:02pm
Mark
GTH-L Simplicity
