wd with a v8?
ewbs79 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ewbs79 Quote  Post ReplyReply Direct Link To This Post Topic: wd with a v8?
    Posted: 17 Mar 2011 at 3:43pm
hey guys i have a wd that i'm contimplating a v8 swap the engine was pulled years ago and is toast. busted block missing parts etc... Who can tell me how to adapt one of my v8s to this the inside of bell housing measures 13 inches and the motors i have all have at least a 13 to 14 inch flywheel ive seen some pictures of real good installs but no details
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2011 at 4:04pm
Ya have an adapter plate made. I think Johnny Cash got his from JC Whitney for the 49,50,51,52 psycobilly Cadillac, but you won't find one to fit you needs.
 Really you would have to figure out how thick the adapter plate needed to be, put in a bolt pattern for the Allis housing and hopefully the engine mounting holes would be on a different pattern.
 That plate will probably cost about as much as buying a running replacement engine.
Edited by CTuckerNWIL - 17 Mar 2011 at 4:06pm
junkman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2011 at 7:20pm
just a thought. Some gleaners had a chevy engine in them. maybe you could find one of then.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ewbs79 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2011 at 9:20pm
What happens if a guy would machine out the centers on both flywheels and weld the appropriate center on the wd flywheel? Could it be balanced? Then use an internally balanced v8. Would the wd starter have enuf umf to crank it? Then an adapter plate from motor to bell housiong is a snap.
dharpo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dharpo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2011 at 9:31pm
I believe that a 390 ford will bolt right in. years ago a guy had one that he pulled with. if memory serves i think he used the wd flywheel.
AS LONG AS THERE ARE SHADE TREES I CAN BE CALLED A MECHANIC
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2011 at 9:42pm
You need the WD flywheel and clutch and a custom made adapter plate, usually a 1/4 inch plate is adequate. From there the big trick is getting the bolt circles the same so everything lines up. Most likely the installation of a V8 will require some frame modifications. The last two that one of my friends did were 353 Detroits. He had to widen the frame by 4 inches to get it to fit.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2011 at 6:27pm
Seen at Hutch a couple years ago, Chevy 327 very well done....just a bit of inspiration.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ewbs79 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2011 at 6:39pm
Wow wee it looks good wish I knew all the specs.
49WF View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 49WF Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2011 at 10:12pm
The owner of the tractor in picture above is standing in between the mufflers with black hat. He is a machinist and makes the adaptor and the flyweel adaptor. EXCELLENT work ,we purchased one for my son's WC. I don't remember his name but he lives close to HUTCH.
More than I need
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2011 at 8:14am
Anyone know what the shaft,sprockets and chain are for in the second picture ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2011 at 8:16am
That is the modification to the steering.
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2011 at 7:45pm
I personally like the way the hydraulic pump mounts where the flat belt pulley mounts. never seen this but sure a good idea. still say get a backing plate from a combine equipped with a chevy engine.
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2011 at 8:25pm
While an overhead valve V8 is the easiest and cheapest engine to choose, I like the vintage look of an old Ford flathead V8 in these kind of conversions.  They also have a very unique sound to them.
Mark
GTH-L Simplicity
