old allis disc
allis1984 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis1984 Quote  Post ReplyReply Direct Link To This Post Topic: old allis disc
    Posted: 16 Mar 2011 at 8:05pm
Iv got a 13 foot allis disc with the gangs set straight do you think it will work good just to knock down stalks. We are notill planters, but go the go ahead for some tillage to hard to see the markers in them thick stalks.
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2011 at 8:29pm
Why not try your rotary hoe? That would do a good job knocking down the stalks and not mess with the dirt as much as a disc would. You could also run twice as fast with the hoe.
Edited by John (C-IL) - 16 Mar 2011 at 8:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis1984 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2011 at 8:36pm
yeah thought bout that but i dont own one and already own the disk its our secondary disk and lighter than the 2500 we have
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2011 at 9:44pm
The only thing I see that will be an issue, is if you use a disk even at a very shallow angle you esentually have a marker mark ever 10" or so, your planter maker disks will be hidden amoung the other disk marks, unless you are going to drive at a decent angle to the rows.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2011 at 8:06am
After thinking about this for a while, why are you even using markers? I follow the old rows. You could also plant at an angle, BTDT, spraying is a major PITA. Final option is GPS, the BTO guys use auto steer. I'm thinking of putting the GPS from my sprayer in the planter tractor this year.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis1984 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2011 at 4:38pm
we use markers to see where we are in the feild. If you didnt use markers you would be over lapping to much or too little. Only the big time farmers can afford that gps
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2011 at 4:44pm
A flail chopper would work but then if you don't have one. I doubt a disc with the gangs straight would do much. These new hybrid corn stalks seem to be tougher all the time.
This page was generated in 0.328 seconds.
