Allis WD stalling laugh of the day
Popps View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Popps Quote  Post ReplyReply Direct Link To This Post Topic: Allis WD stalling laugh of the day
    Posted: 15 Mar 2011 at 11:49pm
Finally got the WD going like it should. It would start right up and idle fine but when given more gas or put under load it would die. I cleaned(several times) the fuel line, sediment bowl, lower carb etc. and still had the same results. I finally decided I would do one more cleaning and if that didnt work I would get the carb rebuilt. This last time I removed the float and stuck above the needle was a little peice of trash. This little bit of trash was just enough to stall it out at operating speed and to throw me off of the problem. I just couldnt figure out why a tractor that seemed to be getting enough fuel would act up like it was. While I dont claim to be mechanical this is one lesson I wont soon forget!
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2011 at 7:15am
Patience wins again, along with stick to it and look for the details...does make you feel good when you can find the solution
This page was generated in 0.647 seconds.
