D14 serial number location
jtheise4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jtheise4 Quote  Post ReplyReply Direct Link To This Post Topic: D14 serial number location
    Posted: 14 Mar 2011 at 2:52pm
Can anyone please tell me where the serial number is located on a D14?  Thanks.
JeffMOnt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JeffMOnt Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2011 at 2:58pm
The serial number is located on the right side of the tractor (clutch side) by the bell housing.
Here is a link with a picture and serial listings.
http://www.oktractor.com/d14data.html
Edited by JeffMOnt - 14 Mar 2011 at 3:01pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2011 at 6:20pm
Hay Jeff
It's on the LEFT side on both my D-14s, I know, you guys in 'TO' get confused...hehehe
Jay
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2011 at 9:35pm
Yes, left side (when sitting on the tractor).
onetotaltoolman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote onetotaltoolman Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2023 at 5:44pm
Do the engines in the D14 tractors carry a seperate serial number? Working on the valves now. There is a different procedure (slightly) for different engine heads in the d14. The book refers to a model number, but i'm not sure if that is the serial number on the bell housing , or if there is a different number actually stamped on the engine. Anyone know?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2023 at 6:03pm
the TRACTOR serial number is on the left side, bell housing flange... the ENGINE serial number should be in front of that, on the engine flange.... I believe all the D14 engines had the 149 cubic inch motor, so the serial number will be 149- xxxxxx.
This page was generated in 0.496 seconds.
