7000 series 4wd?
Peterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Topic: 7000 series 4wd?
    Posted: 11 Mar 2011 at 11:39pm
anyone ever seen one or made one? what would you have to do? or would ya just put the older sheet metal on a 8000 series tractor. id think they would look pretty awesome. but thats just me.
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
kip in cny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kip in cny Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2011 at 12:31am
I seen a 7020 4 wheel drive.  It looked nice I dont know who made it.  Its on a farm in groton NY.
160 CA 920diesel 5020 HD-3
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2011 at 7:21am
"Mud-Hog" company made hydraulic driven front axles for the 7000 series that utilized the tractors existing main hydraulic pump. To have a driveshaft driven front axle would require an 8000 series FWA rearend.
Russ-neia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2011 at 8:52am
Norm denies it, but surely they had to have some 7000 series prototypes to test the FWA before introducing the 8000 series?  The rear housing on the 70 was designed for FWA, just not machined out and no gears inside.  There is a plug where the driveshaft would come out.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2011 at 9:44am
One of Norm's books states that 4wd was planned for the 7000 series, but was shelved to move the 7000 series project along more quickly.  There was also a picture of a prototype from around 1970.  Would have been good if they had it available when the black bellies came out.
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2011 at 10:19am
I arrived in the tractor engineering department in 1977.  As posted above, we worked with Mud Hog for an aftermarket kit for the 7000's.  Part of the reason that FWD wasn't pursed harder with the 7000's was that the FWD axles available then didn't have as sharp of steer angles as those developed in the late 1970's.
The prototype 8000 tractors were totally prototype 8000 tractors complete through the cab and engine hp settings with FWD axles from Sige in Italy that had sharper steer angles.
One interesting tale for the testing of the FWD  8000 tractors was getting a call from the test department that there was a major problem.  They had gotten into a field condition where the tractors were hopping terribly.  They thought the gear/tire ratio between the front and back was the problem.
I went out to the field where a big disk was being pulled in some sandy, dry soil conditions.  Yes, the tractor would start hopping if the disk was set deep enough.  Of course, if you turned the FWD off, the tractor would just spin out all together.  I had them do some slip testing and it turned out that the wheel slippage was well over 15% when the hopping started.  We knew from previous testing with the big 4WD tractors that they would hop also if tire slippage got over 15%, so I stopped worrying about it.
It did get me out of the office for a day, however!!
Mark
GTH-L Simplicity
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2011 at 1:56pm
the hopping is from radial tires isn't it? They don't like to spin smoothly like a bias. They are always trying to grab traction.
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2011 at 3:05pm
Hopping happens with both bias and radial.Conditions in practice make the difference to hop or not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2011 at 6:34pm
Hopping will occur (regardless of tire construction) on a 4WD vehicle when slippage gets too high (unless it's on ice).  LOL
Mark
GTH-L Simplicity
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2011 at 9:56am
Mark, do you have any photos of the 7000's with the Mudhog or any of the 8000 prototypes?  They are more my vintage and what we still farm with, so I love seeing/learning more of them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2011 at 12:04am
yeah i would love to see some pics of them.
Byron WC in SW Wi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Byron WC in SW Wi Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2011 at 7:48am
427425 - That's interesting to hear stories from that time and also for the information.   Sometimes my tractor will hop and now I know why.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2011 at 10:18am
Sorry, but I don't.  I was never that impressed with the Mud Hog as the efficiency of the hydraulic drive was not good.  It was really only useful in muddy conditions-------not normal field work.
I also didn't take many (if any) pictures of the 8000 prototypes except the 8095 that I've previously posted here.  I knew the 8000's would go into production, but that the 8095 (should have been called 9025 or 8225) was a long shot when I did take a picture of it.
Mark
GTH-L Simplicity
This page was generated in 0.210 seconds.
