Dozer epinions
good-dog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote good-dog Quote  Post ReplyReply Direct Link To This Post Topic: Dozer epinions
    Posted: 10 Mar 2011 at 6:14pm
Does anyone have any thougths on a 1975 Allis Chalmers diesel crawler.Are they a good reliable machine, are parts easily found, what do you think of the price.Will want to put a backhoe attachment on
thanks see link
http://ontario.kijiji.ca/c-cars-vehi...AdIdZ238017154
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2011 at 6:40pm
655 is update of the HD4 machine , seems a little high on price but ? AC 2200 Nat asp engine, 3 speed trany with fwd-rev clutch pack and torque converter. 655 should be pedal steer rather than lever steer.
As far ad hoe on the machine I had on on my HD4 and still have the hoe
AC 615 hoe , 14' dig , Cessna hyd rotary piston swing, 24" bucket. (which i would sell)
I found i went trough 3 axles, 1 bull gear, on input shaft gear (upper drive gear) had to machine case on both sides from load from hoe putting to much stress on rear case on bearing races.
 Without counterweight machine was to light in back and would walk on front idler with loaded bucket, with hoe on machine and empty bucket it walked on rear sprockets, weight transfer was real bad ..
Edited by Coke-in-MN - 10 Mar 2011 at 6:45pm
This page was generated in 0.258 seconds.
