8030 questions
orangepower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangepower Quote  Post ReplyReply Direct Link To This Post Topic: 8030 questions
    Posted: 09 Mar 2011 at 8:32pm
i been looking at 8030's both tractors lose there prime, why, ?  is this a common problem? they been sitting on a dealers lot. next one 8030 has a problem once you get it primed, it will only run from 1000 to 1300 rpms, then it will flutter out and die if you accelerate. they think its injection pump. what do you think? how much for injection pump rebuild? thanks for replies.
45 diesel puller, 45 gas puller, ca puller
niel ev View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote niel ev Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2011 at 8:48pm
It could be enjection pump or something as simple as the rubber o-rings have gotten brittle  Niel
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2011 at 12:00am
I have a 7040 that did the same thing. I replaced all the O-rings and still no change. Looking further in depth I had 2 lines rubbing, one had a hole so small that fuel wouldnt leak but would suck enough air. It took 2 people to start it, one to crank and one to push the primer and spray ether.
