7060
slims75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote slims75 Quote  Post ReplyReply Direct Link To This Post Topic: 7060
    Posted: 09 Mar 2011 at 2:31pm
Have a customer with a 7060 that is complaining of low horse power.  Dyno'd @ 100 HP.  Check and re-set injectors, rebuilt pump, checked compression, set valves. Now it Dyno'd at 110 HP.  Found intake gasket to be blown, fixed that and now at 115 HP.  Have took intake hose off of turbo to eliminate inlet restriction and muffler off to eliminate exhaust restriction, fuel flow is fine.  Has 14lbs of boost under full load.  Turbo turns fine and has no play but that is what I am leaning to because of the low boost.  Also there is very little smoke at full load which is very abnormal for these tractors.  Anybody have any other suggestions.
chllngr528 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chllngr528 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2011 at 3:00pm
If you had a turbo problem she would be bleching black smoke. What's max boost suppose to be?
Post Options Post Options   Thanks (0) Thanks(0)   Quote slims75 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2011 at 4:54pm
I think it is supposed to be around 18 @ rated and max load, I agree about the smoke, but it has got me stumped and the turbo is about all that is left.  The tractor starts good and sounds good also.
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2011 at 5:06pm
Can you check fuel delivery from the tank? We had a 7060 with a plastic fuel line from the tank that had a similar problem, we replaced it with a rubber hose line with a much larger inside diameter and it made a new tractor out of it.
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2011 at 5:12pm
have you checked the type of fuel they are using a friend of mine lost a lot of power in one of his tractors when he ran a tank of bio diesel through it.  He was pulling a 20 foot disk that he usually pulls in eighth gear at 3/4 throttle and had to drop a gear and run wide open to have enough power to run at the same speed. The only thing that changed was the type of fuel, when he filled it the next day he used regular diesel and had all of his power back.  I also noticed this with a diesel pickup, it had been filled with bio diesel and I though it felt gutless and when I stopped to refill it during the trip I used regular diesel and it came back to life, this was a couple years ago but I have not put bio diesel in anything since.
Just my opinion,
Denis
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2011 at 5:15pm
Which injectors???Bosch or AC ??? It ain't the turbo.
Post Options Post Options   Thanks (0) Thanks(0)   Quote slims75 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2011 at 5:18pm
Bosch injectors, gonna hook it up to a 5 gallon bucket of our fuel tomorrow and re-check it, it also is one of them with the electric lift pump but everything checked out on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2011 at 5:22pm
Are the Bosch tips the correct P/N ?? also I never set them higher than 3600 psi....if you're at 4000-4100 psi like the book says it will hurt HP some but not 50 hp....Turbo boost is more like 16 psi at 160 pto hp @ 60 degree air temp.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2011 at 6:08pm
We had an electric lift pump that was pumping air in the fuel, like to have never found the problem - as stated, get a CLEAN supply of diesel and bypass all filters - go directly into the back of the pump for a short check.  If this fails to increase HP take the top of the pump and make sure the metering valve is contacting the smoke or torque screw -if equipped - also seeing a lot of gummed up metering valves that could be the problem.  I guess also a check of the transfer pump pressure would be in order as suppose these relief could stick open as well - but not likely. Worn blades or broke spings could hurt  though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2011 at 6:09pm
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2011 at 6:42pm
You have a fuel problem, is my guess.  I would say test your fuel pump on a test bench with the spec from an allis chalmers service manual, do not rely on the pump overhaul shops database as I have had two pumps set wrong by the same shop and when I took in my service manual it was quite clear why I had no power.  a 210 with 104 hp and a rebuilt pump set at 71 cc, book said 87 I think, boy did it change that tractor when the pump was set to what the service manual said.  It did not raise the boost pressure much, maybe two pounds.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2011 at 9:01pm
Injector lines get eroded on inside. I have saw new inj. lines bring the HP back up.  MACK
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2011 at 9:46am
I have seen this happen on an 8050, the pump had been replaced and timed correctly to the engine, the tractor had no power, but ran fine otherwise, it turned out the front dampner had moved so the timing of the pump showed correct, but in corilation to the crankshaft it was actully off.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2011 at 12:56pm
I have been a fuel injection tech for 15 years, and I have never had anyone complain about the factory spec not being correct. The #'s you gave are close, a 210 spec at rated is 71-75, and peak torque is 82-84cc. It is the same as my AC manual as well. Ed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote slims75 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2011 at 3:34pm
Finally gave up  and put a different pump on it and it dyno'd perfect. so i am sending pump back to get re-checked, Thanks
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2011 at 3:56pm
Thanks for reporting back, get us an update when you get the pump checked out.
