WD45 governor question
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Topic: WD45 governor question
    Posted: 08 Mar 2011 at 6:37pm
Pulled the governor today to replace the gasket. Is it necessary to reset the ignition timing when I put it back on? Is there any easy way of doing this?
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2011 at 8:37pm
I hate to rush an answer but I'd like to get it put back on tonight yet if I do not need to set the timing.
Luke.
German Shepherd dad
#WD234847
#WD88193
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2011 at 8:37pm
yes
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2011 at 8:47pm
If you mark the pointer and don't turn the motor it should be timed the same. Would be good to check the timing after you get to running.  MACK
