where to get a seal
dustinmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Topic: where to get a seal
    Posted: 07 Mar 2011 at 8:03pm
I need a front seal for a C where can I get one? I cant find them in the parts houses, Thanks, Dustin
niel ev View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote niel ev Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2011 at 9:11pm
Which one do you need ? Niel
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2011 at 5:59pm
the front crankshaft seal
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2011 at 6:15pm
Motion Industries, but you'll probably need the shaft diameter and the bore diameter that the seal goes into or the old seal for them to match up to.
Edited by CTuckerNWIL - 08 Mar 2011 at 6:16pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2011 at 6:27pm
 I have the dia's but it will need to be the 2 part seal with the felt and rubber, atleast that was what was in it or what was left of it anyway
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2011 at 6:36pm
You might want to get a speedy sleeve also. Someone on here might remember what size. I used one on a B and a new style rubber seal and have no leaks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2011 at 6:50pm
The new rubber spring loaded seal should work fine. If there is a noticeable groove in the seal diameter, get a speedi sleeve for it. You might not need a speedi sleeve if the new seal casing is narrow enough to place it so the seal rides on a good surface.
Edited by CTuckerNWIL - 08 Mar 2011 at 6:52pm
dannyraddatz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dannyraddatz Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2011 at 7:31pm
I bought mine from AGCO and don't forget to pack the back side of the seal with grease so the spring will stay in place during installation.
Danny Raddatz
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2011 at 9:33pm
I will check with agco, the ones I could get are for the 138s 149s and 160s and the outer dia is too big I already destroyed one getting mad and trying to MAKE IT FIT  with a hammer
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2011 at 1:00am
The outside diameter is bigger than the bore it fits in. My brother would always take the CR seals to the belt sander before installing to put a bevel on the leading edge. If you don't have the proper tools, get a socket that is just a little smaller than the seal and us it as a punch. The seal MUST be kept parallel with the face while inserting.
Edited by CTuckerNWIL - 09 Mar 2011 at 1:03am
